This question is in reference to Atlassian Documentation: Configuring issue linking
Ask your question here...
Hi Arumugam,
As mentioned in the documentation, you can add your own link types. They can be named whatever you want.
From your question it sounds like you might be asking about Gantt chart dependancies/relationships between tasks:
Are these the relationships you mean by "fresh-fresh", etc?
If so, while you can create your own link types along these lines, JIRA doesn't have functionality to restrict user actions based on them.
For example, you could create a "Finish to Start" link type, and link two issues with it, but JIRA will not actually prevent one issue from "starting" until the other issue has finished.
To implement restrictions like that, you'll need to look at add-ons (like JIRA Workflow Toolbox, which has the ability to block or hide workflow transitions depending on issue links).
Finally, if it is Gantt chart type functionality you want, have a look at add-ons like Gantt-Chart for JIRA which provide this. There are a number of others, so you should research which fits your needs.
I hope this answer helps. If not, please add a bit more information/details on what you are trying to achieve and I am sure someone will be able to help.
Sam
Thanks Sam - Question is about types of issue/stories linking method. Is all the 4 mentioned types are possible of linking new/fresh to finished issue, fresh to fresh, so on..
Ah. I see. So you mean can you link a closed/resolved issue to an open issue and vice versa? Yes you can.
