Automation rule - create issue if issue with the same summary doesn't exist
Ana MINCA
July 30, 2021
Hello,
I have the following process that I would like to cover via an automation rule:
  • Every day the team needs to do some checks in production (each time the same ones)
  • In order to make sure they do not forget this step and we also have stats regarding the checks I would like to create an automation rule that each day, at the same time automatically creates a ticket in their Kanban board that contains the exact same information
Until here I have no issues, I managed to create the rule and the rule is triggered everyday at the specified time with the exact same template.
  • As an additional layer, I want to check if the created ticket from the day before is in any other status then "Done", and if it is I want to not create the one scheduled for the current day (ex: If today is Tuesday and I still have in progress the ticket from Monday the rule should not create a new one)
Do you have any suggestions about how I can achieve this?
Thank you !
2 votes
Gareth Cantrell
July 30, 2021
@Ana MINCA
You can insert a JQL Condition immediately before the Create new story action, and use a query similar to the following:
type = Story AND summary ~ "Summary of created issue" AND resolution = Unresolved
Ana MINCA
July 30, 2021
Thank you for the answer. :) It works !
Alex Koxaras -Relational-
Hi @Ana MINCA
I would insert a JQL check prior of the action for creating the issue, just like the following image (don't mind the "Manual" trigger):
The JQL statement is this:
summary ~ "My Summary" AND status != Done AND (created >= startofday(-1) AND created < endofday(-1))
I would change the "My Summary" wording with the summary you give when creating the ticket.
Let me know if that worked.
Alex
