Is it possible to Auto-add comment to parent issue based on transition of subtask issue in OnDemand instances ?
David Griffin April 26, 2013
Is something similar possible for JIRA OnDemand users ?
We are looking forward to add a comment to the parent issue on resolve of a sub-task - but the "copy field value to parent issue" post function is not able to copy a comment so we started to look for a "workaround" but could not find a specific answer to our question regarding OnDemand instances yet.
Nadir MEZIANI
April 28, 2013
Thank's @Harry Chan, this isn't available for OnDemand.
I haven't try the JIRA OnDemand version, i use instance in my local machine, but; I think that we can do it with javascript (in screen resolution) and REST-API (
/rest/api/2/issue/{issueIdOrKey}/comment
) http://docs.atlassian.com/jira/REST/latest/.
Good luck
Harry Chan
April 28, 2013
Hi, this isn't available for OnDemand. There are ways to do it using a downloable instance self or externally hosted.
Nadir MEZIANI
April 27, 2013
you can do it with JJUPIN plugin scrip or jss (Jpython) scriptin or devlop your own plugin.
Harry Chan
April 28, 2013
Does this work for OnDemand though? It's restricted https://confluence.atlassian.com/pages/viewpage.action?pageId=315326753
