Hello,
I'm trying to change the default background color for the help center's banner. After choosing the color and applying changes, nothing happens even 5 -10 -50 mn later.
Do you know if it's a bug or how can I resolve this ?
Thx !
Yup , there is a problem with the usability . You need to explicitly choose the color and apply for the banner color to get reflected. Hope it helps
Refer the attached image
I found out that, to actually choose, I had to click Choose after choosing the color. A UX masterpiece indeed <g>.
