You've been invited into the Kudos (beta program) private group. Chat with others in the program, or give feedback to Atlassian.
View groupJoin the community to find out what other Atlassian users are discussing, debating and creating.
I have Java base project with sbt.build and need help and direction how to setup Clover for it.
I am using Jacoco as of now and its working fine for Unit test cases. But it don't have good support for get coverage against functional testing.
Does clover supports coverage against functional test.
For Example: I want to measure my application development code coverage against my functional Front End Automation tests.
Hi Saga!
The Atlassian Clover (i.e. version up to 4.1.2) has one SBT plugin available here, but it's in the very early stage of development:
https://github.com/shanbin/sbt-clover
The OpenClover (an open-source fork, not maintained by Atlassian, version 4.2.0 and higher) has another plugin written by a community member, see http://openclover.org/blog:
We have new plugin for SBT
Thanks to one volunteer, OpenClover has a second plugin for SBT: https://github.com/barkhorn/sbt-clover. This plugin supports newer SBT versions, links with OpenClover and SBT's internal tasks (test in Test, compile in Compile) are used for the build, rather than a custom scope.
Hello everyone, I am a product manager in the Jira Cloud team focused on making sure our customers have a delightful experience using our products. Towards that goal, one of the areas which is extr...
Connect with like-minded Atlassian users at free events near you!
Find an eventConnect with like-minded Atlassian users at free events near you!
Unfortunately there are no Community Events near you at the moment.
Host an eventYou're one step closer to meeting fellow Atlassian users at your local event. Learn more about Community Events
